Valley ATV Club
HID conversion
Recommended Posts
Kinda slow around here :dunno: The lights on my quad kinda suck, I was looking into adding LED bars and even the LED lights the chef has, but rather then add on to the quad (and also burns more power) it would be better to replace the existing lights with HID. Found these kits on Ebay for $38 each. Two sets is enough to replace all four lights and will draw the same power as the existing lights.
Will post the results, have to dry out one housing first, I already have an idea where to mount the ballasts. They are listed as fully waterproof so they should be ok for the quad.
Share this post
Link to post
Share on other sites
Guest MtnBob
They look real good Mike, Do you have a link to the website?
Thanks
Bob
Share this post
Link to post
Here is the link, Ebay site
http://www.ebay.com/itm/270890515433?var=570053762354&ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
All Cats use 880 style bulb. (except the 366/425i models) I purchased the 6000K bulbs.
Went out locally for a night ride and wow! what a difference. I also have to account for since my frame and plastics are "tweeked" the headlamp housings do not line up properly. Today I plan to do a quick ride at Lost Trails and take a picture inside the tunnel. I have pictures from before I did this change. So I will have an accurate "before & after"
These are 37 watt kits which means they do not draw any more power then the stock lights. I bought two kits to do both set of lights which still made it cheaper then adding LED light bars and such.
The only downside is it takes 5 to 10 seconds for the lights to come up to full brightness.
Share this post
Link to post
Here is a good example of the difference. Both pictures taken inside the tunnel at Lost Trails. he difference is amazing. That is even accounting for the headlights are not aimed properly because the plastics and frame are out of alignment.
Share this post
Link to post
Looking good Mike. You can lead the night ride at potter...lol
Share this post
Link to post
I will probably bring in a set to show how they hook up. I ordered one more set as a spare. Should arrive before the meeting.
Share this post
Link to post
A few pictures of the installation of the HID kit for those who want to use them. Bob, these should help you in how to install them. I kept them forward of the oil cooler so they don't get too hot.
They are simply ZIP tied to the front frame with larger zip ties. They have been working out well with no issues.
Share this post
Link to post
Guest MtnBob
Thanks Mike,I got them in in less then an hour. HUGE difference in the lights. Hope they hold up.
Bob
Share this post
Link to post
